Re: Lube for front wheels?
Posted by rustred on November 10, 2009 at 05:59:08 from (142.179.188.160):
In Reply to: Lube for front wheels? posted by Mike CA on November 09, 2009 at 14:33:15:
you need to do it manually if you dont have a brg. packer. you take a small gob of grease in the palm of one hand and hold the brg with the other. then press the brg into the grease and pull it towards you.you will see the grease work its way through the rollers and out the top. keep turning a bit till you have the whole thing done.forgot to mention that first is to wash all that old grease out with varsol and dry them clean and check condition of brg.
