Re: What kind of wire wheel do you use?
Posted by Greg-N-CA on November 10, 2009 at 06:03:27 from (207.69.139.159):
In Reply to: Re: What kind of wire wheel do you use? posted by Tom Fleming on November 10, 2009 at 03:26:35:
I agree with Tom, but HP of the electric motor driving the wheel
is important too. I have a 1/3 HP grinder for the small items
with a fine wire wheel, a 1/2 HP motor dedicated to a medium
wire wheel that I made with an arbor adaptor from a hardware
store, and a 1 HP grinder with the coarse wheel.
This combination and electrolysis; there isn't anything I can't
clean down to the parent material. As always, wear eye
protection and buy American.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
