Re: What kind of wire wheel do you use?
Posted by CNKS on November 10, 2009 at 09:25:53 from (216.144.104.128):
In Reply to: What kind of wire wheel do you use? posted by Mike CA on November 10, 2009 at 01:13:34:
Stay away from sheet metal. On cast you can use any type of wire wheel, but brass won't do much. You cannot hurt cast. I use an angle grinder, but use an electric drill also, because of the variety of wire products available. The twisted wire mentioned is best on an angle grinder. I wear normal glasses that I use for close work. Do not try it without some sort of eye protection. Small parts are best done on a bench grinder with a wire wheel, provided they will "fit" I do all rods, etc that way.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
