The wire wheels are okay for a lot of things, but you need to get one of those 4" scuff wheels for your angle grinder if doing any sizable area. It kinda looks like a sponge, but it is hard. They are more spendy, but take off old paint a lot better, and can leave a surface good enough for painting. They are very good at fixing the "paint over paint over old chipped paint" problem and will take paint down to bare metal. You must be careful not to abuse them as they wear away fairly quickly if you concentrate pressure too much or run across sharp edges with the spin the wrong way. They cost more but last better than sanding disks and you don't have to swap grits.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
