Re: Engine Dies After a Load
Posted by Janicholson on November 10, 2009 at 14:18:32 from (199.17.6.25):
In Reply to: Engine Dies After a Load posted by Mark J. on November 09, 2009 at 17:01:42:
The waiting 20 seconds is a sure sign of fuel delivery problems. Take the fuel ilne off at the carb (there is a screen in there as well) and run it into a jar or can. it should flow for 2 minutes into the can with a flow great enough to fill a quart. JimN
