M.D . grounding switch
Posted by Fallon on November 10, 2009 at 16:14:43 from (75.106.233.102):
Rebuilding the mag on my 1948 MD. The wire from the mag grounding switch has been cut and not attached to the mag. Would like to get it set up right. Do you take off the two nuts at the front end of the intake manifold? And once I do this is their an actual switch that can be changed out. Its hard to see how it is set up in the service manual. Also why would the switch be cut in the first place, and would any harm be done leaving it unattached. Not sure of the purpose of it or how it works. Thanks for any info;
