Posted by tractorsam on November 10, 2009 at 16:24:39 from (99.192.48.1):
In Reply to: SA governor revisited posted by Dellbertt on November 10, 2009 at 16:16:02:
It can be caused by any combination of things but if you haven't already I'd try syncronising the governor to the carb. On the LHS of the tractor there is a yoke on the front end of the link to the carb from the governor. Remove the pin. Set your throttle lever (up by the steering wheel) to full throttle (tractor not running, by the way). Push the link rod you have disconnect to the full throttle position on the carb. If the pin will now go back through the hole you're all set. If not adjust the yoke until the pin will fit in without tugging on anything. Hope that helps, Sam
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
