Re: What kind of wire wheel do you use?
Posted by gene bender on November 10, 2009 at 17:43:34 from (67.55.226.179):
In Reply to: What kind of wire wheel do you use? posted by Mike CA on November 10, 2009 at 01:13:34:
When you want to get serious use a cup wheel on an angle head Millwaukee grinder.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
