Re: What kind of wire wheel do you use?
Posted by GA Dave on November 10, 2009 at 20:02:40 from (74.176.59.221):
In Reply to: What kind of wire wheel do you use? posted by J Heitkemper on November 10, 2009 at 01:13:34:
I've used flap discs with good results. David....................
http://search.harborfreight.com/cpisearch/web/search.do?keyword=flap+disc&Submit=Go
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
