wardner, i have a w-6 parts book here, there are 2 weight options for the w-6. serial numbers 501-6162 the first weight pn 8076d is 126 pounds. the second and third weights, pn 8077d weight 137 lbs each. on the w-6 serial number 6163, the first weight 9114d weighs 145 lbs,, second and third weights are the same part number. i have my book on the super w-6 at home, i will see if i can get the part numbers for those weights.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
