Expanding a bit on Jim’s post: If the engine reaches full RPM with the governor handle pulled/held all the way back, the governor is adjusted correctly. The handle tension problem then involves the governor control rod adjustment.
The governor control rod is the rod runing from the handle at the steering wheel to the bell crank over the manifold. The end of the rod is fitted with a “governor control rod equalizer” - an elongated C-shaped metal clip containing a pair of springs and a swivel nut. And yours is likely is out of adjustment.
Anyway follow Jim’s procedure to adjust the swivel nut in the equalizer – your problem should disappear.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
