Re: Front wheel bearing race question
Posted by Eastsider on November 11, 2009 at 12:27:31 from (204.73.192.210):
In Reply to: Front wheel bearing race question posted by Mike CA on November 11, 2009 at 11:51:07:
Yes, those are original parts, and if possible, you should re- use
them. They are basically a grease retainer that keeps your bearing
grease near the bearings, rather than going into the center of the
hub, like the place all your sand is found. They are available for
your hubs through IH, and you would have to order them
separately. There should be two of them, one for each bearing and
race combo.
