Re: Two H seat questions
Posted by athjol carr on November 11, 2009 at 13:37:35 from (132.181.71.211):
In Reply to: Two H seat questions posted by Mike CA on November 10, 2009 at 23:03:02:
Unbolt the locking support bracket where it connects to the seat pipe and you should then be able to rotate the support bracket to get the long arm through the slot in the seat rail. Then undo the bolt at the seat pivot to take the seat off. It seems that the rail under the seat was rivetted to the bottom of the seat though on my W-4 tese were replaced with small machine screws when someone restored the bottom of the seat
