Re: Front wheel bearing race question
Posted by Roger46 on November 11, 2009 at 18:02:40 from (70.219.85.171):
In Reply to: Front wheel bearing race question posted by Mike CA on November 11, 2009 at 11:51:07:
I have never put those back in and I have rebuilt quite a few of them and never had any problems. As others said, they are to retain the grease in the bearing, but with today's modern wheel bearing grease the grease stays in the bearings. These wheels turn so slow even in road gear that grease is not going to get spun out of the bearings. Automobiles and trailers of recent times do not have these and they are spinning at much higher rpm and under hotter conditions with no problems. Roger
