If it uses a 12 volt battery Id buy a 12 volt starter (and see next Para.), but if it uses a 6 volt battery then I would buy a 6 volt starter.
NOTE its possible to run a 6 volt starter at 12 volts, although it can be a bit tough on centrifugal Bendix Inertia type starter drives, I have recommended use of a lighter 12 volt batetry in such cases with only like 500 to 600 CCA while our friend Bob M simply uses lighter battery and ground cables like a No 2
HOWEVER you cant hardly use a 12 volt starter with only 6 volts, she would crank tooooo slow if at all under a load
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
