Re: My first electrolysis tank... and some questions
Posted by Dave H (MI) on November 11, 2009 at 19:10:07 from (205.188.116.73):
In Reply to: My first electrolysis tank... and some questions posted by Mike CA on November 11, 2009 at 17:44:59:
I have a tank set up year around in my little shop. I am not aware that I ever had it jump to 6 amps so cannot tell you what the effect would be there. I use a rectifier and the amount of amperage varies with the quality of the scrap piece. Lye does remove paint as I believe any caustic solution will eventually. It doesn't always remove ALL the paint and not all paints come off at the same rate. Some sheet right off and some have to be scrubbed a little. I change my solution about every six months when it gets cruddy. It seems to lose it's strength after a while and I have never tested Ph or anything like that to find out why. I just dump it and replace it. Get some heavy rubber gloves.
