Re: Farmall F 12 volt conversion
Posted by F-Dean on November 11, 2009 at 20:13:15 from (67.72.98.94):
In Reply to: Farmall F 12 volt conversion posted by Clyde Rogers on November 11, 2009 at 17:10:22:
Chill! Unless your new F-?? is extremely hard starting, the few revs the starter makes will not be affedted by 12 volts.
However, if you are still worried, take your starter to a repair shop and have them check it over to make sure it is fine for 12 volts.
