Posted by pete 23 on November 12, 2009 at 10:14:22 from (173.87.147.73):
In Reply to: Hi Speed M posted by Glen E. on November 11, 2009 at 19:10:27:
All H and M's up to the 1586 drive the pinion shaft at engine speed when they are in direct drive. The smaller tractors like C on down have no direct drive as the upper shaft in trans is in line with crankshaft and the lower shaft in trans has the pinion. There fore they can change the final pinion shaft ratio by using different gears in trans. When they boost horse power by increasing rpm of engine they can still maintain ground speed by using different gears whereas with a direct drive situation you are always tied into engine rpm as far as max road speed. I always felt that was not the best design but I could surely do nothing to change it. Lots of complaints over the years about needing a gear between 4th and 5th and or slower 5th but when pinion shaft speed is directly linked to engine rpm it would require a totally revamping of the entire trans and final drive.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
