Re: wide front M
Posted by Janicholson on November 12, 2009 at 11:01:36 from (199.17.6.222):
In Reply to: wide front M posted by ron9 on November 12, 2009 at 10:53:22:
The axle will likely work, the attachments points and bolt holes are not compatible. (M is 2" wider, and the steering bolster shaft plate holes are also different spacing. It can be reworked to fit, but welding cutting and fabrication is needed. JimN
