Re: dual fronts?
Posted by scot in pa on November 12, 2009 at 13:20:00 from (12.171.163.54):
In Reply to: dual fronts? posted by Pat-CT on November 09, 2009 at 18:14:14:
Caster is the lean forward (negative) or rearward (positive) of the vertical steering axis. Camber is the tilt in (positive) or out (negative) of the wheel.
I think that's how the positive and negative works, positive is better for handling, negative is worse.
The inside wheel turning more than the outside is called akerman or ackerman.
