Re: Six volt system hooked up backwards
Posted by scot in pa on November 12, 2009 at 14:10:35 from (12.171.163.54):
In Reply to: Six volt system hooked up backwards posted by Dave H (MI) on November 08, 2009 at 11:48:21:
What would be the procedure to change it over to negative ground? Swap the regulator and cables? Or is there more?
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
