Re: My new Project
Posted by Mike CA on November 12, 2009 at 16:55:34 from (99.28.152.102):
In Reply to: My new Project posted by CVA59 on November 11, 2009 at 15:59:14:
CVA59 said: Can anyone please tell me how to remove the governor shaft from the carb so i can rebuild it??? :?
I'm assuming you have already removed the air hose and the fuel line. What you see is the cover for the shaft. The shaft is just pressure fit in there. So, remove the screws that hold it on, and remove the bolts that hold the carb to the manifold. Then you can work the carb off the shaft with a gentle twisting motion.
