Re: Front wheel bearing race question
Posted by gbs on November 12, 2009 at 17:12:06 from (68.115.201.90):
In Reply to: Front wheel bearing race question posted by Mike CA on November 11, 2009 at 11:51:07:
simple fix to grease staying in bearings,and keeping dirt,water ,etc.out, is to install a grease fitting into bearing cap when bearings and seals are replaced, pack bearings as normal,after reinstalling hub cap slowly fill hub until grease starts coming out of the seal, hub is full,no place for contaminates, a few shots of grease from time to time keeps bearings purged they last a lot longer ,you don't have to worry about forcing seals out with the grease because most tractor front wheel seals are designed so lips will face outward when hub is installed.
