Re: What kind of wire wheel do you use?
Posted by PurdueAg on November 12, 2009 at 17:28:50 from (198.109.220.6):
In Reply to: Re: What kind of wire wheel do you use? posted by Roger46 on November 11, 2009 at 18:23:03:
I agree with GA Dave. The flap disks are definately a must-have in the rust/paint removal aresenal. They do a fine job.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
