Re: Farmall 340 - No Spark
Posted by Janicholson on November 13, 2009 at 06:03:54 from (199.17.6.222):
In Reply to: Farmall 340 - No Spark posted by John Ratu on November 12, 2009 at 19:50:30:
If it ran before you did the tuneup, it may need the little insulator at the distributor connection pass through reset. the little bolt can touch the housing.
With the ign on, remove the wire at the distributor. then brush it up against the terminal. if it sparks (low voltage spark) the coil is probably OK. Do as Old indicates to see if the points are working. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
