I agree with the other gents, A gennys output is increased EITHER by spinning it faster (smaller gen pulley or bigger crank pulley) or pumping more current through its field windings. However, on the old cutout relay systems that used the LHBD light switch for field current regulation, in the High charge position (and/or with lights on) shes already set up for max field current (max charge). Soooooo at real slow idle RPM's the gennys simply NOT charging the battery as once its voltage drops below that of the battery the cutout relay that connects the genny to the battery opens. i.e. the battery isnt seeing or connected to the genny anyway, and you dont want it to because then (gennys voltage less then battery) the genny becomes a LOAD sucking up battery current versus putting charging amps back into it.
Other then change the genny or the pulleys things that can help are a good tight belt and good grounds on the genny and especially a good light switch ground
Slow idle plus lights on just didnt get the battery charged much or none at all even when all was new on those type and age of tractors, it sorta goes with the territory
Ol John T (Ima gettin old my batteries dont stay up well either it seems)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
