Re: 350 U progress
Posted by big fred on November 13, 2009 at 13:55:17 from (130.76.32.144):
In Reply to: 350 U progress posted by TomA on November 13, 2009 at 10:16:08:
those lines from the hydraulic pump can lose prime, and when that happens you lose hydraulic pressure and steering. Best way I found to prime the lines is to blow a little low pressure (not more than 5-10 psi) into the vent hole on top of the reservoir, under the seat. If you decide to clean the screen, keep in mind that the reservoir cover is kind of clumsy to lift, and heavy enough that you'll be well served to use a engine hoist to lift it. the screen extends below the cover, so be careful not to set it on the screen, as you will crush it.
