Gear shifter-1949 Farmall H
Posted by Tim Eagn on November 13, 2009 at 14:28:58 from (66.227.228.43):
Sometimes my 1949 Farmall H gets stuck in two gears and have to try and move shifter back and forth until it gets back to neutral. Today that back and forth did not work and had to take off shifter and use screwdriver to get gears back to the neutral position. The bottom of the shifter rod is worn. Anybody have the spec as to what size it should be so I can weld a piece to end and grind to size?
