Re: Help Identify
Posted by ScottyHOMEy on November 13, 2009 at 14:59:49 from (64.222.246.143):
In Reply to: Help Identify posted by 1944bgardner on November 13, 2009 at 14:27:39:
If it's a narrow front IH and the seat is offset to the right side, that would make it a B or BN (essentially the same tractor, Bs were 8" wider acrosss the rear than the BN). The A had the seat offset, but was a wide-front.
