Re: IH 400 paint and trans
Posted by Wardner on November 13, 2009 at 17:27:23 from (4.154.240.244):
In Reply to: IH 400 paint and trans posted by *MMIHJD* on November 13, 2009 at 16:45:12:
If your shifter is in the right hand hole that means that the differential ring gear is on the left hand side. This will mean reverse operation with five gears in reverse if tractor looks otherwise normal.
Does it run? Have you driven it? Are there drop boxes hung off the outer end of the rear axle housings? Some are chain drive and others are gear drive. They will also affect direction of travel.
Put up a few pictures and we will tell you what you have.
