Posted by rustyfarmall on November 14, 2009 at 04:07:06 from (209.152.78.140):
In Reply to: Super H won't start posted by Mark on November 13, 2009 at 19:07:33:
The super H carb uses that double float, just like an M, and it is very easy for the float to get "tweaked" so that it actually rubs the sides of the fuel bowl. If the float cannot move freely inside the fuel bowl, it cannot drop down to allow fuel to get in, and it cannot rise up to shut the fuel off. When you rebuild one of these carbs, you always should hold it up to your ear, turn the carb upside down and then turn it right side up, and listen for the float moving inside. Yes, you CAN hear it.
It is also quite possible that NEW float valve is a bit sticky and just isn't dropping down enough to allow a sufficient flow of fuel. Clean both the needle and the seat with aerosol carb cleaner BEFORE installing. I've also been experimenting lately with spraying a small amount of silicon lubricant on the viton tipped needle before installing. It does seem to help.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
