Re: Using Dex-Cool, Dex Cool in old Tractors
Posted by karl f on November 14, 2009 at 10:26:36 from (209.188.106.159):
In Reply to: Re: Using Dex-Cool, Dex Cool in old Tractors posted by karl f on November 14, 2009 at 10:10:56:
by the way, factory fill extended life coolants are not compatible with each other between ford chevy chrysler imports.
dexcool is organic acid technology (OAT).
some others are hybrid-OAT (HOAT)
there are a few more types too, how many four letter words can you spell ending with OAT?
the same color doesn't mean the same chemical make up either. it's kind of crooked in a way.
the universal types like prestone promise full compatibility with all factory fills when used to top off and work just as good or better when used to fill completely. i'd rather change it all than mix types though.
karl f
