I think the extra filter capacity would be a great idea and should help pump life. That being said, there are a lot of different types of pump failure on these series including the wearing out of the pto shaft spline and gear that drive the pump. Lots of time compensator was the problem, sticky spool. Polished several that would stick when warmed up, cool down and worked ok again. Plugged orfices or blown o-rings. The swash plate actuating piston would also stick in no flow positon. Found a couple of them. If you take the pump apart and the ball sockets are worn on the slipper pivots it is definetly cavitation causing it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
