Posted by Wardner on November 14, 2009 at 17:35:31 from (4.154.242.213):
In Reply to: Re: shifter posted by Wardner on November 14, 2009 at 17:07:25:
I took another look at your picture.
You don't have a standard row crop axle housing but I can't tell exactly what you have. If there is a gear drive drop box bolted to the end of the axle, that will reverse the operation. Two reverse configurations (right side shifter and geared drop box) will give you 5 speeds forward. If the box is chain drive, that won't happen. The axle housing could also be a non adjustable W-400 housing or similar part. If that is the case, you will have five speeds in reverse.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
