Posted by Andrew Z on November 14, 2009 at 17:38:52 from (64.252.130.179):
In Reply to: distributor plug? posted by brian 1855 on November 14, 2009 at 17:31:29:
they are a point to oil/grease the workings. put a zerk fitting in them, however you need to be very careful not to over grease the shaft. there is anouther plug on the other side when it comes out that one you stop. this is what it says to do in the manual. no more than 2 to 4 strokes should be enough.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
