Farmall H valve setting
Posted by kurtis219 on November 14, 2009 at 18:00:04 from (207.190.123.169):
im looking for some advice, i replaced the head gasket on my farmall H, the intake and exhuaust valve gap settings are both .017 , do i set the valves cold right after it is all assembled , or do i check them cold, start it and run it till it warms up, shut it down and then set them. any info would be appreciated, thanks kurt
