Posted by Owen Aaland on November 14, 2009 at 18:12:07 from (65.165.246.148):
In Reply to: distributor plug? posted by brian 1855 on November 14, 2009 at 17:31:29:
Over greasing the bushing in the distributor is not a problem. If you use excess grease it merely comes out the hole on the opposite side. There is no hole in the bushing for the grease to reach the shaft but rather you are putting the grease on the outside of the bushing where it can be absorbed into the bushing to lube the shaft.
If you over grease the front zerk, the one that lubes then reduction gears, grease can be forced through the inside of the distributor shaft bushing and get inside the distributor housing and get on the points.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
