Re: Super A Water Temp Gauge
Posted by ScottyHOMEy on November 15, 2009 at 05:51:31 from (64.222.246.143):
In Reply to: Super A Water Temp Gauge posted by Dellbertt on November 15, 2009 at 05:32:41:
Whoa!
You're talking about two different temp gauges.
The lead from the middle of the filter cover on the hydraulic block is for hydraulic fluid temp. That runs to a gauge mounted near your hydraulic controls.
Your probe for your coolant temp gauge, if the tractor even came with one, will be in one of two places, either in the upper outlet between the head and the radiator or in the lower inlet between the radiator and the crankcase. I'll take a look at the Parts Book here shortly, cause I don't know if they mopved the coolant temp gauge on the super a back to the seat. On the As and Bs, it was mounted to hang off to the side of the governor.
