Re: My new Project
Posted by Mike CA on November 15, 2009 at 10:01:59 from (99.28.152.102):
In Reply to: My new Project posted by CVA59 on November 11, 2009 at 15:59:14:
Where is it? It's zoomed too close to be able to tell.
"concerned" depends on you. It looks like a shade tree fix. Lots of welding, and the addition of a non-stock plug bolt. If it works, and you don't mind the way it looks, then it's of no concern in my opinion. But since it's a show tractor, you may want to take some time on it. Get a bolt that doesn't stick out so far and take a grinder to those weld beads before you paint it.
If someone was doing an original restoration, they've probably have to replace the rear end. But you don't have to go to that extreme.
