Re: H Model Charing trouble
Posted by glennster on November 15, 2009 at 11:12:37 from (24.14.63.246):
In Reply to: H Model Charing trouble posted by VFMerc on November 15, 2009 at 06:22:18:
something else to check, i had a charging problem with my h, replaced and re-wired everything. genny bench tested fine, motored fine, but when installed on the tractor just would not charge. turns out the insulation around the a terminal on the genny was cracked, and when the wire installed and tightened up, would short out the genny.
