Posted by CVA59 on November 15, 2009 at 11:41:47 from (68.90.129.240):
In Reply to: My new Project posted by 550Doug on November 11, 2009 at 15:59:14:
Mike CA said: (quoted from post at 11:01:59 11/15/09) Where is it? It's zoomed too close to be able to tell.
"concerned" depends on you. It looks like a shade tree fix. Lots of welding, and the addition of a non-stock plug bolt. If it works, and you don't mind the way it looks, then it's of no concern in my opinion. But since it's a show tractor, you may want to take some time on it. Get a bolt that doesn't stick out so far and take a grinder to those weld beads before you paint it.
If someone was doing an original restoration, they've probably have to replace the rear end. But you don't have to go to that extreme.
It is right under the belt pulley PTO down on the side of the transmission case. I will get a bolt that is the right length. I would be hesitant to grind on those welds too much since they are brass. It would take quite a bit to get them smoothed up and clean. I was thinking of building a nice can type cover that would cover just the area of weld and use the bolt to hold it in place. I am afraid this has dampened my aspirations of having a real nice 100% original tractor without going to extensive lengths to replace the case and a couple of other imperfections. I do not have the place or time or money to get into completely changing out cases and big pieces like this. I will fix it up as best i can i hope it turns out looking ok.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
