Re: Super A Water Temp Gauge
Posted by Adrian Billheimer on November 15, 2009 at 16:21:10 from (173.86.31.255):
In Reply to: Super A Water Temp Gauge posted by Dellbertt on November 15, 2009 at 05:32:41:
Dellbertt,
Yes, the Hydro temp probe is the one going into the touch control tank.
When you remove it, you will be draining the fluid out, according to the owners manual, approx. 6 3/4 pints.
The 4 bolt plate where the probe mounts is also the strainer for the hydraulic fluid.
I replaced both of these on my 53 Super A this past spring, I don't recall the prices, but Scotty's OEM price, I think was a little higher than I paid at my local CNH dealer.
