farmall H no power
Posted by kurtis219 on November 15, 2009 at 16:42:56 from (207.190.123.169):
i recently blew the head gasket on my farmall H, got it rebuilt this weekend, everything looked good when i had it tore apart. put all new gaskets in everywhere, torqued everything, set the valve gaps. i changed the oil once, started it (starts and idles great) and ran it for 10-15 minutes, then changed the oil again. it starts great and runs nice and smooth, but when driving it doesn"t have the power it should. i can"t pull even small hills without it choking out and dying, what else should i be checking out to fix this problem, thanks
