Re: H Model Charing trouble
Posted by farmallhal on November 15, 2009 at 17:02:08 from (76.4.163.116):
In Reply to: H Model Charing trouble posted by VFMerc on November 15, 2009 at 06:22:18:
I had the same issue as noted by glennster on my Super C. My main issue on my generator was it needed a new armeture and during the process of the electrical shop installing a new one it wouldn't work when I put it back on the tractor. I used Bob M's trouble shooting techniques he emailed me and found it was still a generator problem. I took it back to the shop and they quickly found the issue and replaced the termainal and insulator and still working fine several years later. I believe you can damage that post by not holding it in the fixed installed position and if it turns when tightening the stud nut when hooking up the terminal you have a good chance of breaking the insulator between it and the generator case. Hope yours is this easy as well, Hal.
