Re: Farmall H Steering trouble
Posted by glennster on November 15, 2009 at 18:20:39 from (24.14.63.246):
In Reply to: Farmall H Steering trouble posted by kippster on November 15, 2009 at 16:24:04:
carter and gruenenwald sells the rebuild kit for the front ends, has both bolster bushings, bottom bearing, steering worm shaft lower bearing seal and bushing for about 150 dollars, as you are going to have it apart, now would be a good tome to freshen up the front end. also yt here also sells the steering shaft for about 172.00 and the upper sector gear for about 80 dollars. if yours are worn ie lot of slop, she'd drive like a porsche when done!!
