Re: shifter
Posted by jess in ca on November 15, 2009 at 20:50:49 from (69.225.6.206):
In Reply to: shifter posted by *MMIHJD* on November 14, 2009 at 16:16:44:
the top deck you have here is made for a low drum cotton picker, when you reversed your gears you switched the shifter to the oppisite side,
