Re: 3388 Hydraulic pump
Posted by pete 23 on November 15, 2009 at 21:22:02 from (173.87.147.73):
In Reply to: 3388 Hydraulic pump posted by haymaker421 on November 13, 2009 at 13:26:49:
On the filters again, the 2+2 used two small filters because the steering pump took it's oil through the end cover so due to this configeration the one large filter would not work as you needed the screen cold oil bypass in between. If you broke the shaft I am almost positive you have a worn out pto shaft and gear also. I have had to replace them.
