Re: H Model Charing trouble
Posted by VFMerc on November 16, 2009 at 03:47:48 from (98.110.125.83):
In Reply to: H Model Charing trouble posted by steve il on November 15, 2009 at 06:22:18:
Thanks Hal. That may be it. Seemed when I was going over the generator the first time I had reinstalled it and found no charge. The shop had placed the V/R on and wired it and I didn't check that terminal. I thought I had simply failed to check and tighten the nut. I didn't remove or inspect the wires. If the insulation was cracked I would not have seen it. I'll take a look and then run the motor test. I sounds similar to your situation in that I took it back to the shop and they said it was putting out voltage but I'm not seeing it.
I'll give it a try.
