Re: VR is too tall to fit??
Posted by CNKS on November 16, 2009 at 07:38:01 from (216.144.104.128):
In Reply to: VR is too tall to fit?? posted by Mike CA on November 15, 2009 at 18:04:47:
Mike, the regulator is higher because of the "shock absorber" rubber things. The original was lower because it mounted directly to the generator. If moving the regulator in the slots doesn't work, you may be able to drill the rivets out, toss the rubber and lower the regulator.
