Re: VR is too tall to fit??
Posted by rustyfarmall on November 16, 2009 at 07:44:33 from (209.152.78.140):
In Reply to: VR is too tall to fit?? posted by Zach Bouchard on November 15, 2009 at 18:04:47:
CNKS said: (quoted from post at 08:38:01 11/16/09) Mike, the regulator is higher because of the "shock absorber" rubber things. The original was lower because it mounted directly to the generator. If moving the regulator in the slots doesn't work, you may be able to drill the rivets out, toss the rubber and lower the regulator.
I thought about that also, so I went out to the shop and looked at an original saddle mount cut out relay that is hanging on the wall, and it appears that Mikes' voltage regulator MIGHT actually be setting lower than what that cut out relay would, so maybe that voltage regulator just needs to be repositioned?
